Cv Joint '93 St182
HarveyCP
Hello, I'm having a problem getting an outside, off-side CV joint for my
'93 Celica.
I ordered one and was got an Isotrans part that was supposed to be correct
- and also fit a Camry - but the thread end is a smaller diameter than mine,
the main body length is slightly longer and slightly larger diameter. But the main
issue is the length of the splines in the inner race - they are about 4mm longer
than mine and as a result it won't go on far enough for the spring clip to engage
and hold the joint on the shaft. ADL/Bluepoint apparently only have one part number for the car as well. Is this a problem that anyone might be able to shed
some light on? I'm a bit stuffed otherwise.
Hopefully..., Jamie
cant you go to a local motorist shop and match it up ????
I've ordered another one from a different manufacturer - none of them stock
this sort of thing around here - and I'll match it against mine. But I'm concerned
that the only one supplied so far - with the correct part number and no others to
choose from - is the wrong one...
