Hello all,
In the past week or so I've received a Toyota Corolla 1.8 2021 Icon hatchback.
I've been trying to register multimedia on the website/app but I'm having trouble finding the device ID.  I can't seem to find system information in the menu.  My device doesn't appear to be on the list of 4 it gives you as examples, but I tried following the instructions on each of them.  I've attached a couple of images in case they're helpful.
Does anybody have any advice?
Hi John.
I had the same problem when I got my Corolla. I can't remember the full details how I did it now but I do remember that I had to connect to a wi fi hot spot and then go into the Toyota Online menu in the car's info system. From there I was able to retrieve a long registration number which showed up on thr info screen. I then was able to go on the Toyota website on a pc and register my infotainment system.  All Toyota dealers will have a Wi Fi hotspot if you get stuck and may even help you with your problem.
You can't register multimedia as you do not have Toyota navigation, with Toyota navigation you get additional features and "online" appears as an option in the LH menu set here you add your account details and the car connects and the info appears on the app.
Ah right.  Is that something I would have had to get the dealer to install, or is it something I can do?
There is no UK option for the nav as it's designed to be used with a mobile device with Android auto or Apple Carplay for the nav/apps
the manual is a European wide, English manual, so it covers lots of markets and options
The biggest downside is you need internet access to use most of the map services though there are a few options to use maps stored on your phone
You're not the first and sadly will not be the last to come across it
