Does the Avensis T25 2003-2006 has the same doors as the 2007-2008?
ulflun
Hi guys,
Does anyone know if the rear doors from T25 2003-2006 is the same fit as the 2007-2008 (T25 facelift) ones?
Have a big dent on a 2007 rear left door and have found a 2006 with same color at the scrapyard.
The facelift seem to have trim list but otherwise looks very the same. Does anyone know for sure? We're not allowed to return the parts at the scrapyard.
Seems like the OEM part number is 67114-05030 but I can't figure out if it's the same for 2003-2006 as 2007-2008.
Thank you in advance
Not 100% sure about this but EPC shows 2006 T25 Avensis left rear door part number is same.
Thank you! I also looked at another EPC and it seemed like the same product number (without trim). Unfortunately the color code mismatched so I did not buy this door. I'll keep watch for a replacement door.
For further reference. A door from pre facelift fitted straight on and everything works - lock, power windows etc.
Now I just have to move over the small trim, which is attached with adhesive, then it is done.
