Urgent! Help Needed.
daktari
:help: I`ve just driven back from town. (7miles) and have a strange noise which i can only describe as sounding like a cross between a high pressure fluid leak and someone crumpling up a sheet of celulose plastic. !!!! Bit like a power steering leak with added sound effects.
The strange thing is it only happens on left hand bends over about 30mph. And appears to be coming from the drivers side. The side with the suspension under compression.
I`ve had a cursory look underneath, in the engine bay and around the shocks. Also checked all the fluid levels. Nothing apparent.
Has anyone experienced this or does anyone know what it may be???? (Apart from expensive :crybaby: ) :( :( :(
TIA
Dak
SOLVED. Beware saggy exhaust mounts. The inner rear CV boot was rubbing on the exhaust when the suspension compressed. New mounts = No noises. :D :D :D
