Toyota noah fuse box location
Hi could anyone please tell me the locations of the fuse boxes on a 2004 toyota Noha trying to wire up dash cam thanks
Worth checking the side of the driver and passenger footwells (behind the trim)..that's where my Estima has fuse boxes. (mini fuses)
Looked and can't see any
Noah - behind the glove box - left-hand side
Looks something like.............
Found it thanks now just need to locate grounding bolt and the cable for the reverse light
Ground to anywhere metal on the body - reverse signal (usually a red wire) in the body loom that comes from the back on the passenger side it can usually be found behind the passenger side, A pillar, kick panel
  • 4 months later...
