12 volt battery
Stefense
Why does A/C drain my Battery and kill the engine?  Check engine light came on but no codes show up.  I turn the A/C off the check engine light goes away and car is perfect?
Moved to the Prius club.
Hi how old is the 12v Battery it could be past its best
21 hours ago, Stefense said:
Why does A/C drain my battery and kill the engine?  Check engine light came on but no codes show up.  I turn the A/C off the check engine light goes away and car is perfect?
Low gas? When was it last filled?
15 hours ago, ian rooke said:
Hi how old is the 12v battery it could be past its best
I change it and the coil pa
I changed it the hybrid Battery and the coil packs
I changed it the hybrid battery and the coil packs
I put new gas every 2 weeks
I changed the 12 volt the hybrid Battery and the coil packs
When PaulDM said “low gas” I took it to mean the air conditioner unit is low on its gas, not low on petrol.
Do you really mean you changed the hybrid Battery, that’s the big Battery in the rear and costs a lot of money.
Do you really mean you changed the hybrid battery, that’s the big battery in the rear and costs a lot of money.
That’s exactly what I meant. Lol.
