OBDII : LONGFT1 -15% at idle
Biomecanoid
Hello,
I just checked my car with the OBDII tool and found the Long term fuel trim to be -15% when parked idling.
I do remember both short and long term fuel trim being at 0% a few days ago.
I don't believe this is normal, Anything I can do ?
Thank you
Chris
Any work been done on the car ? What's the MAF flow/MAP reading? can you check it with another scan tool as it should throw a lean code and be running like 3 legged donkey
It could be a slow O2 sensor, again you need to look at the values
On 23/05/2021 both short and long fuel trim was at 0%.
Air filter is clean, ( also run the car without the filter no change ) and on 10/05/2021 I added to the fuel STP Fuel System Cleaner.
I thought since the car is 15 years old and still with the original fuel pump it must be dirty
I don't know if its relevant but I also have a CAT_RDY INC.
Car is running fine no errors codes or check engine light, nothing weird
I will upload photos of the readings from the scan tool.
Photos:
iat is at 37 degrees what is the outside temperature ?
Yes we have a hot summer here :P
Any ideas ?
Anyone cares to contribute ?
