Yaris Hybrid 2018 Head Light Upgrade.
Szetok
Does anyone know why the xenon head light does not work on the 2018 hybrid.
I put the xenon headlight in and it does not comes on put the old bulb back and it works.
Tested the xenon directly with the Battery it works .
Check the relay on the fuse box and the fuse both OK.
Notice the 12v dropped to nothing when the xenon connected but OK with the normal bulb.
Thanks.
Kelly
The metal connector blades (pins) that are on the xenon bulb may be thinner than the ones on the original bulb, so they are not contacting properly.
Just an idea...
What make of bulb ? Did you buy the correct type of bulb ?
