Hi I have a 2006 Toyota Argo 1lt. In 4th and 5th gear rattling quite a strong rattle and idea what it is ? The car has full service history and has 75,000 miles on the clock.
Bearing and/or synchro, the lack of oil kills these gearboxes, rebuild or replace while you're at it do the clutch
Car been into the garage, turns out passenger front tyre has a massive bulge in it. So just a new tyre needed. Thanks anyway.
Interesting read, how does what was assumed to be a gearbox issue turn out to be a tyre issue but cause a rattle in 4th and 5th gear?
Higher road speed in 4th and 5th gear causing more vibration because of the bulge in the tyre, and hence rattle.
Makes sense now, thank you.
