Hi all,
I have a carina 2.0 td 1997/98 R reg
Whilst changing my cambelt the mechanic has noticed the power steering pump pulley has a piece broken off and the woodruff key is missing
Toyota can't get a new pulley till the end of the month and its expensive!
Does anyone know if someone is breaking a carina td?? Or of a pulley and possibly pump
I can see lots for the 20td they used in the early avensis, same engine 2ct but they pump is a different design. Does anyone know if I could use that unit instead as they are easily available on eBay
Bob
The pulley is 44311-12030 looks like a dealer only part
As fitted to these diesel cars
That's really useful thanks Flash
It looks like the pulley on the 2.0td avensis will work as well but the power steering pumps on sale on eBay for the avensis look different?
Can you do me a favour and see if they changed pump design between the two cars but on the same 2ct engine, I cant see why they would have
Bob
The pulley is the same, the pump is specific to the Avensis
As an update. My mechanic managed to weld the broken pulley and I ordered a replacement woodruff key from Toyota (very expensive for what it actually is!) and it's working fine so far.
