Yaris verso Keyfob
amazighman
Hi .
The wife got herself a Toyota yaris verso 2003, and needs a spare key.
We only have black master key , so should be able to add other keys to the system.
If i get a second hand Keyfob from eBay , does the pcb or chip thing have to be the same looking as existing key? Or same number ?, although numbers at the back of the existing key have faded away.
There are many keys out there stating.its for yaris corolla celica etc. Are they all same?
Thanks in advance
There are 3 types the 2 main ones are Valeo and Tokai Rika
can you PM me your vin so i can look it up
I will PM the vin to you when Mrs back with the car , as we don't have logbook yet.
Here are couple of pictures for the key internals if it helps
Thanks for your help
If you peel back the rubber, there will be a number on the pcb
Seems like tokai rika key fob , does the number have to match too?
That number relates to the manufacturer and model
Thank you very much indeed .
They are expensive for a second hand keyfob , but i suppose better than paying 100s at dealers.
I need to get a blank yaris key from eBay , are the blade length and casing same ?
Something like this maybe?
 https://www.ebay.co.uk/itm/181846110890
I need to get a blank yaris key from ebay , are the blade length and casing same ?
Toy43 blade is correct add another £3-5 for a decent locksmith to cut
£15 untested, it's a gamble
Thanks for that.
