Good morning all
I am currently in search of a replacement radio. The code on the face of my radio is 13845 (This is displayed next to MP3) Although the majority of the radios that I can find in the second hand market is 13821. Does anyone know what these codes mean? and whether this radio would be compatible?
Appreciate any help
Terry
On 6/5/2021 at 11:52 AM, TerryHoops said:
Good morning all
Appreciate any help
Terry
Hmmm... This is a tough one, as the different ID-numbers hints that they are indeed different, BUT...it does not say if its just a different color on the frontfacia or if it has more or less functionality thatn the other one.
The best way is to get pictures of the rear of the units and compare plugs... IF...the plugs are identical, as these raiod are fairly straight forward, it should work.
I have extensive knowledge about the ID-numbers on Toyota's headunits, but unfortunately the ID's for LHD cars, that i'm more familiar with are different 🙂
@TerryHoops
13816 and 13821 are pre 08/2010
13844 is 08/10-05/14
13845 is 08/2010 onwards
13845 - Toyota part number 86120-52C80
It, maybe cheaper and more convenient to go the aftermarket route, tho the fascia is a bit pricey
Not sure if https://www.dndservices.co.uk/
can do a repair for you
  • 2 years later...
Fascia is cheap aint pricey! I replaced the factory head unit which is what you had; I replaced it with an Alpine ILX702D best decision I ever made, as far as head units go. Sounds fantastic and looks sweet, interior looks updated, never was really naff anyway. 1 criticism is the silver fascia trim that goes round the head unit and air vents would look better black. But the aftermarket fascia looks exactly same as the standard 1 (which obviously is shaped to accommodate the standard head unit that was replaced). Another critique not relevant for the head unit but just in general  are the gauges - it would be better if there were more info displayed better like I know you can see mpg average and current etc but it’s a one button push to change displays and looks
Alpine ILX702D in Toyota Urban Cruiser
