Dash lights don't dim
Ray Albert
I have a version two Yaris and when I turn on the lights the dash lights don't dim. The dash is too bright for night time driving. Has anyone had this problem and managed to rectify it.
Turn the ignition on
turn headlights on
Then using LH button on instrument display cycle through options, one of them will be a segmented bar with this displayed press an hold same LH button this will then cycle through various brightness release at the desired option.
Brilliant. Thanks a lot.😄
The thing i find annoying about this is that brightest is too bright, but any other level is too dark. There's a big gap between brightest, and 2nd brightest.
Wish they fitted a classic dial  so you can adjust it better.
