Door unlocking problem
Jungenas
Hello, cant find problem thats the same as mine, the problem is that when i unlock my gen 3 2010 1.8 prius, it unlocks front passenger door straight away, but struggles with other 3, it unlocks faster, from about second try if i use key fob and about 5th try if i use keyless entry. When i lock the car there is no issue, it locks straight away.
Have you checked the voltage on the 12V Battery?  If so, what is it with the car off for 2 hours or more.
How old is your 12V Battery.
When was the Battery last replaced in the key fob?
