Coolant draining avensis t27 with 1ad ftv engine
strand10
Thanks for reading this. Doing a coolant change and wondering how much coolant should I expect to drain through the radiator drain plug so that I have enough fresh coolant to do the refill.
thank you
thank you
many miles on it when are u supposed to change that thought lasts a real long time
210,000 miles. It’s well over due new coolant. I have a few litres of Toyota long life coolant but what I’m wondering will most of the 7 litres capacity drain out or just the few litres in radiator.
Ok job done. About 4-4.5 litres of coolant drained out, it was in good enough condition but good to get some fresh coolant in. Make sure to squeeze the radiator hoses a few times after filling to get rid of air and top up accordingly. I used Toyota pink coolant.
I don't have this engine, but there is supposed to be a drain plug on the engine block close to the bulkhead.
http://www.japan-parts.eu/toyota/eu/2012/avensis/adt270r-awfeyw/2_273560_009_530W/tool-engine-fuel/1105_cylinder-block/1
http://www.japan-parts.eu/EU/2/115582C.png Look *4, top left of the image.
http://www.japan-parts.eu/toyota/eu/2012/avensis/adt270r-awfeyw/2_273560_009_530W/tool-engine-fuel/1105_cylinder-block/2 http://www.japan-parts.eu/EU/2/115584B.png 11415A/11415 or 11432A are the drain plugs.
