@Bob110023 I'm beginning to think you have somehow applied a corrupted update although that shouldn't be possible since it performs a checksum comparison during the process.
I don't think anyone else has reported anything like you are experiencing. I did have two cases at first of it not knowing exactly where I was but that never happened again.
Might also be worth posting the version information from your head unit because I think I have seen mine either freeze and continue with voice instruction or the reverse once or twice in the past but not since I got the latest firmware update.
Then again maybe it's your head unit. It seems unlikely but I think most of us here have found the satnav to be reliable. It might be a bit primitive but it has rarely if ever glitched on me.
Good points raised Andrue. I have downloaded the update again on a different USB stick. I will try and install again tomorrow, head unit permitting. Thanks for your info.
Hi. 2021v1 downloaded again and reinstalled. Everything seems to be working correctly. 🤗
