Hello everyone,
I have Corolla E12 HB, 2005y, face lift with low spec, and I wanted to install front fog lights that weren't installed by default, however it's pre-wired in the bumper. I bought the fogs, the light switch, where front and back fog lights are integrated, put everything into their places and sadly they won't work, even the light in dashboard does't show up.. Maybe someone can tell me what i need to complete the upgrade?
Would suspect it needs a relay or fuse fitting as well ?
This US diagram should be very similar to your model.
Generally the fog light switch is part of the steering wheel lights switch assembly, assume yours does not have the fog light part fitted ?
Thanks for your replay, I've noticed, that there's actually a place for FOG relay in one of relay boxes. The relay seems to be missing, just ordered a new one, it should help. If everything will be fine, I will share how I made this upgrade.
