ok lads i aint been on here in a while but need a little advice for a mate.
he has a 97 starlet and has gone and got the head ported and polished along with cams reprofiled from piper. but i need to know what way u would go about gettin the fuel set right cause he is talkin about bigger injectors and fuel line etc. which i think is a bit much.
wats ur ideas ??
regards gerard
It depends on the other work being done to the engine. Getting the cams reprofiled, and head portpolished.. doesn't mean you need a fuel line and **** if he's using bigger injectors yes, then it owuld be nice to get a fuel pressure regulator..Look also at getting an air/fuel guage for the mixture when your running rich etc.
