Just fitting revcounter to my 07aygo.plug for wires has been cut off and taped up .so Iam stuck which wire goes to which wire any one help . thanks
Where have the wires been cut ?
1423878052_aygotachdiagram.JPG.a08b3ce36
The wire plug that's part of car wires.red.brown.black green.blue.
The colours are as per the diagram above
  does the rev counter have 4 wires (red, blue, white and yellow)
heres what i posted last year for another member...........................
So working this out from pictures, pinouts and C2 housing diagram - Aygo tacho.pdf
Looking at this and other pic's we can see yellow and white are next to each other and a blue
Looking at this one we can see that the brown is on the top row
Looking at another pic we can see 3 wires on the top row in positions 1, 2 and 4 the connector uses 5 pins of the 8, 3 on the top row ergo. 2 on the bottom row
Car Side - Use               -    Pin
Red           IG 12V               Pin 1   Yellow
Black         RPM signal       Pin 2    White
Brown       Ground              Pin 4    Blue
Blue          Illumination        Pin 5
Green       Perm live            Pin 6
The chart above should read
Blue          Perm Live          Pin 5
Green       illumination        Pin 6
Click to enlarge................
Thanks Iam no eletrician I'll have a go thanks for your time
