Im having difficulty finding camber correction bolts for my 2021 sedsn se. Are the struts the same as on the hatchbacks?
Hi, yes most likely same as on the hatch. Not sure if this models has a camber adjustment option as most McPherson front suspension cars doesn’t. , you may only play with Toe in or out. Perhaps best to check Toyota service and repair manual.
Regards
Based in the usa ? There should be no need to touch the suspension on a brand-new car unless your modifying it and throwing the warranty out the window
Eibach usually do camber bolts along with other handling parts
Regards
Our models have the McPherson struts?
All Corollas has front McPherson struts as standard. 👍
