Hi everyone. I've just replaced my pcv valve and his gasket in my TOYOTA AYGO mk1 (1kr-fe motor). Changing the gasket I lost a little piece of that. He falled i think in the crankcase. Where is it gone? Should I be worried about this piece of 2cm x 1 cm of plastic? What should I do?
In american forum they suggested me to do not worry and drive it.
Thanks for the answers
Well, there are two options:
1. Open the sump and take the plastic out.
2. Just leave it in and drive like that , it will stay at the bottom of the sump in oil bath. Will it cause damage, most likely not since it’s covered by oil and it’s a light weight plastic gasket but can you be 100%?sure, also not .
If it’s me I will probably take it out. 👍
  • 2 years later...
hi I want to clean or replace my pcv (mk2 aygo).....did they use the same pcv valve for the mk1 and mk2?
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
