Connect original back camera to new radio/nav player
Mlv
I bought a new radio/nav player for my Toyota Auris: https://aliexpress.com/item/32963329471.html
This one comes with a backup camera with a RCA jack to plug into the player. But I rather retain the original camera from Toyota that was installed at the factory.
Does anyone have experience with this and knows if and how I can connect the original camera to my new player?
Thanks!
You will need a 16 pin camera retention lead, there are various manufacturers/seller
Thanks for your response.
This one should be fine. Where exactly do I need to connect the red & black wires to?
On 6/25/2021 at 1:23 PM, flash22 said:
There doesn't seem to be a 16 pin plug in my car I can connect it to. Do a need a different adapter?
I am not sure which of these plugs is from the rear camera.
That is the earlier setup, so you will need the 20 pin version
1 - Yellow - Video +
2 - Orange - Reverse +
11 - Black - Video -
12 - Black - ground
