Dashboard information panel dims when I put the lights on
NigelD
 When I switch the lights on in my 2009 IQ  the multinformation panel dims so much I can barely  see it. How do you turn the brightness up ? Am i missing something?
Press the button again ?
Don't mean to sound thick , but which button?
With the side lights on, press the Mode button until you see a series of dashes displayed. Then push and hold the button for more than 1 second which will adjust brightness of the instrument panel light. Fewer dashes, dimmer and more dashes, brighter.
Thank you Mike, I've just picked this up and will give it a go this afternoon👌
regards Chris
Thanks again Mike, it worked a treat.
regards Chris
