Does this Yaris have Bluetooth + Cruise control?
arjanvirdi
I've found a 2018 hybrid yaris, and it has a media system like this:
does it have bluetooth?
Also does it have cruise control? It's the Yaris hybrid active 2018.
That's an odd spec climate control but base radio, Active hybrid has no cruise, Active hybrid is an EU spec so it maybe a grey import from Ireland
The radio is the later Base model 86120-0DC20 it has BT but only basic functions
https://autocatalogarchive.com/toyota/?page_id=17008
Thanks! Can you play via USB port and aux as well? Such as music on a 4gb USB stick.
If you look at your pic there is a little flap for usb and aux
The Active Hybrid was introduced in the UK in 2015.
You may be able to retrofit cruise control. I did to our 2015 Yaris Sport 1.33. I found the stalk on eBay for £12 delivered, and a quick how-to guide on YouTube to remove steering wheel. Once plugged in, it worked
