Hello,
I was wondering if you guys can help me with the search for a supercharger kit for the 2zz.
I did heard that there are some mercedes superchargers available which may will fit?
To find the original one is so hard...
I hope that you guys can give me some helpful information!
Best regards,
Lars
Google is your friend
The 2zz is commonly used in a few lotus cars and there are a few kits on the market, but it will not be a cheap upgrade unless you manage to find parts used
IIrc the Corolla Compressor uses the Ogura TX-12
So difficult to find one. A friend of mine supercharged his lexus is200 which also has a toyota engine in it, with a mercedes supercharger.
He told me that there is maybe one mercedes supercharger that will fit on the corolla too.
If this isn't the case then i have to be patient and hope that i can find one on the available markets.
iirc Merc's use an Eaton M62 or M65 Lotus tuners use the MP62 (the lotus factory ones are an Eaton MP45 or Magnuson MP62)
What is the exact difference between these items?
Might be worth contacting Fensport - They are a well established Toyota performance specialist and they used to sell supercharger kits for all sorts of things, even an Aygo! :laugh:
Just be prepared - One thing this won't be is cheap!!
Tbh you need to research the supercharger - these kits range from £2-6K and it's not a case of slapping a charger on, you will need a piggyback ecu and uprated injectors and have the car mapped
If you want major power you will need to build the engine low compression pistons and uprated rods at a minimum
I have a lot of parts to build the engine.
I know that i have to upgrade my piston and piston sleeves. The ECU is not a problem.
But here in Belgium and holland it's like not possible to find any kit.
That's why i was asking for the merc superchargers. Ofcourse i would like to find an ogura or greddy supercharger.
If you guys know one for sale please share it here 🙂
