Yaris 2001 anti roll bar link
pusseyeyes
Hello Guys
I have just purchased a anti roll bar link I know how to fit it my question is
I'd like to confirm the position of the washers in particular the unique large metal washer. Am I right in saying it goes on the underside of the bottom arm?
I have viewed toyota diagram regarding this but it is not very clear. any photos of the actual position of the washers including the large metal washer would be greatly appreciated.
thanks
What is the large metal washer you refer to?
From memory there are 4 large metal washers and possibly a metal center spacer depending on what style bolt you have..
The one I fitted went something like Nut-Washer-Rubber-ARBArm-Rubber-Washer-Spacer-Washer-Rubber-SuspensionArm-RubberWasher-Nut
This one sorry for the confusion
Oh, is that a proper Toyota one? The ones I fitted were poly-bush ones and didn't come with that, just the 4 washers that clamp the rubbers against the arms.
I have a feeling that 'unique large metal washer' is a seat that goes in a recess in the suspension arm.
