I think I remember reading somewhere that the torque for Corolla Lug Nuts should be
around 90nm. Would you say that is about right ?
Most Toyota cars these days are set at 102Nm, not sure about older Corolla but +-10Nm will not be a big deal. Perhaps you can find your model here and the set values. 👍
https://www.wheel-size.com
Cheers Tony, they have my old Corolla down as 110 nm ..i'll settle for around a 100 so, should be
fine. Thanks once again.
You are welcome
I thought that the dealer/garage standard was 'too much for anyone without an air gun to undo'.
  • Haha 3
These garages are insane for stupidity. Over tighten lug nuts are more dangerous than not tighten enough, when too tight if you hit a pothole or go around bend at higher speeds can snap the nuts(bolts) and loose your wheel.
Definitely complete ignorance and stupidity to blast lug nuts on to twice the spec when lug nuts have a tendency to tighten up beyond normal spec.
In Saudi Arabia torque wrench is spelt "man standing on long bar".
Thanks for the tip. I'll remember that the next time I have my wheels off and I'll just make them finger tight.
lol
Anyway, Finger tightening them is your 'normal spec' ? ..you would be a great candidate for working in a tyre shop and be
loved so much by certain BMV drivers who have had to cut their wheels off because of the finger tighteners lolol.
Thanks, you must think very highly of me if you think I am capable of doing such a technical job.
hahahaha one speed airgun chaps, god bless them all the same. 🙂
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
