Hello all,
Am new to this forum so bear with me.
For some strange reason, the key fob for my 98 corolla wont activate the central locking.and a beeping noise comes from under the bonnet,this noise stops if i lock using the key.The key fob will however unlock the car.Will the immobiliser still be effective.Luckily i dont have the owners handbook and only one set of keys
Thanks in advance for any advice
Albi
ps . the door open idicator continually illuminated
Sounds like one of the door courtesy switches is faulty and has shorted out. It would cause all of the symptoms you've described. A replacement shouldn't cost much if you do the work yourself. On a side note, the immobiliser will still function, as that is independent from the central locking system.
