i seem to have a rattle from the tailgate lock area , i loosened the bolts but theyre not slotted
is the any adjustment on these or do i need to file the mounting holes?
Check the rubber on the bracket of the window motor, also the wiper motor boss can wear meaning the motor can move
can you feel movement in the hatch ? iirc you just need to loosen the strike plate and give it a hit with a soft mallet/hammer
edit. Just a thought the boot handle holds the studs/bolts through the glass this holds the latch, with age and use these studs/bolts pull out/strip the threads of the plastic, iirc these studs/bolts also hold the window motor
its all tight...if you grab the glass theres a little bit of slop
ive wrapped some tape around the bar for now to see if its that before messing too much
You adjust the lock by loosening the 2 bolts either side of the lock, pictured here
pic posted on here by lakeuk.
IMG_20180609_140938.jpg.a695c5aed0e6c7cd
The hole in the body is bigger than the bolts, this allows for movement
should i have that plastic trim to cover it?   2011 car
