I bought an used car very recently, but now it is giving the following problem.
It stutters while taking a turn, the check malfunction indicator blinks....
When I went to the autozone and checked what is the problem....
It said,
Engine 1-5 misfire detected.... error codes are P0300- P03005
How do we normally rectify this problem...
Bye
vishnu
The P030x codes are standard On-Board Diagnostic (OBD) codes.
They relate to engine misfire by cylinder ie P0301 = Cyl 1, P0302 = Cyl 2 .....
Generally they are ignition system faults.
I don't know your car/engine, but since you have all or them it sounds like a wiring fault. Possibly the main voltage (+12v) to the ignition coil(s).
