2014 prado very weak going uphill
ilove2fix
Hi guys my Prado isnt running very well. Very Low power  going uphill. Straight roads its ok but if i floor the gas pedal i dont get any kick just seems weak.  I can barely crawl up a small hill or incline. No engine lights . No noises no smells. Recently changed Oil  , air filter , Spark plugs ( Iridium ) , fuel filter.. Mechanic said trans fluid  is fine and fuel pump is good.
Compression on all 4 cylinders around 214 psi
Also have techstream data here . Maybe something isnt normal?
Injection volume at idle is only 0.11 cc? Is that to low?
Moved to the Landcruiser club.
  • 9 months later...
Hi did you find out the problem ??, My prado is doing the same but the engine management light comes on but goes off when I take my foot off the pedal, I've got it booked into a toyota dealer near me next week
