Change language from Japanese to English Auris 2016
BlackMDK
How to change language on this type of radio:
I don't see language option in settings menu
As it's a Jap import, it will be in Japanese only, as it's designed for the JDM market, also be aware the radio will not work correctly either
2 options
1. replace it with an Auris Touch2
2. fit a good quality aftermarket Head unit
It also depends on your location as to what is available
Thanks a lot for info, just out of interested if we install aftermarket radio will any of the car functions be lost, I know Nissan integrates their head unit heavily with car functions don't know much about Toyota.
Also is there any guide how to remove head unit?
Some do, some dont. Aftermarket dont have that much integration, but almost all work fine with steering wheel controls.
I think main issue is for people with hybrids, you lose the information details about EV side of the car.
Or, you can go with Toyota's Touch2 unit as a replacement.
hi where can i purchase a radio for my 2015 Auris ? need to replace it as its off the JP Market ??
On 7/17/2021 at 4:01 PM, flash22 said:
What country are you located in ?
 Barbados
  • 5 months later...
There are aftermarket units that fit the Auris, some without fascia plate, some with.
I never saw anyone asking for size, but there are a few similar topics, you can use search and see what units they used.
