Hi all, I have an Aeras 2.4 Estima Acr50 2009 and need a new Battery,
I am trying to find an exact match, but the ones I seem to be finding are coming up a little bigger sizewise, but only a few mm.
they are:
Enduroline 068 75Ah CCA 630A  £68
Varta E23 12V 70AH (068 073) CCA 630A £74
S4 026 Bosch Car Battery 12V 70Ah Type 068 S4026 CCA 630A £76
they are all:
Length 261 mm
Width 175 mm
Height inc. terms 220 mm
On Tanya website
Anyone confirm if these are the correct ones before I order please?
If it fits on the tray ok then a few mm shouldn't be a problem
Also ensure that the cable connections can be connected.
Oh I forgot ensure your Battery clamps fit to properly secure your new Battery on the Battery tray.
 Take the Tanya site with a pinch of salt its very hit and miss - check what's fitted to the car first
