Need help installing TTE power boost unit for d-4d
Igor94646
Good afternoon, dear owners of Toyota. I have a Toyota Avensis 2002 (t22) d-4d. Also I have a power increase kit from TTE am 26223 for my car. But I have no installation wires to connect the unit. I want to make them myself, but there are no drawings and connection diagrams of contacts. If anyone has such a block, I would like to ask you to take a close-up photo of your installation wires so that I understand how I can make my wires. From your photos and ECU diagrams of your cars, I can understand what parameters this unit reads and changes in order to connect it to my car. in total I found two types of installation wires AM 26444 and AM 26446, but these are the wires for RAV4, LC and COROLLA. Photos can be sent to ivisnevskij19@gmail.com
Please note that if members reply, they will post photos within their reply to this topic, rather than send them to an e-mail address.
There is little information on these units, TTE no longer exists, tbh the only way is to get one of the harnesses and workout the wiring from a ECU wiring diagram, you can then work out the pinout out for the TTE unit
IIRC these were produced by Denso Ten
TTE_D4D_Performance.pdf
Sorry if I did something wrong. I don't speak English - I use google translator. I asked to send a photo to the address, because if it is a lot of close-up photos, then no one but me will be interested in it. In turn, I undertake to present the result of the work here with a reflection of all the features
52 minutes ago, flash22 said:
There is little information on these units, TTE no longer exists, tbh the only way is to get one of the harnesses and workout the wiring to a ECU wiring diagram you can then workout the pinout out the TTE unit
Thank you, I know a lot more about these blocks than in this broshure. But I never met information about the block 26223 anywhere. I am afraid that these blocks in the world remained quite a bit and the likelihood of finding the installation wires seeks 0. I will be grateful for any information about the cutting of the wires, even from other blocks from Corolla, RAV4 and others.
