Annoying buzzer when braking when towing
MyOpinionIsWorthless
Has anyone had the experience of a buzzer going off every time you apply the brakes when towing in a Prius?
feels like I’ve been pranked by Hammond and Clarkson.
Buzzer from the e pump when pressurise brake fluid for the rear wheels? If this is what you mean I can hear that sometimes more without towing just with normal use
Nope definately sounds like a sounder buzzer. Only when trailer is attached. Not under normal driving.
I'm not too familiar with towing wiring harnesses but I know they may have a buzzer to tell you the indicators on the trailer are working (required in the UK?) - maybe it's been wired ubikways and is also/only buzzing for the brake lights?
Towing?
Prius is not classified in UK for towing.
I'm sure it is illegal to tow a trailer in the UK with a Prius.
2 hours ago, Sooty said:
Towing?
Gen 4 Prius (FWD version) had a towing capacity of 725 kg, nothing illegal here.
Yes only on braking. No sounder for indicators just the hypnotic click click click ….. click.
6 hours ago, Sooty said:
Towing?
Nope. Rated for 725kg since 2016
Ok, I stand corrected.
I know the Gen 2 and early Gen 3s are not allowed to tow so assumed it was across the whole range.
Absolutely true and I agree with your analysis. That’s why I upgraded my gen 2 to a gen 4. Also the gen 4 is still not approved in the USA. Some guys on a sister forum are fuming they can’t tow in California with a gen 4
