Low engine oil
Roxburgh
Low engine oil warning even when oil level is at max
Which Avensis is it (year)?  Which engine - size, petrol, diesel?
Could you be confusing the oil pressure warning light with a level warning .I have owned three Avensis since 2008 and none of them had a low level warning light,only a low pressure warning light.
What he said; Get it to a garage and get an OBD scanner plugged into it to see if it gives any hints why the oil pressure is low; Could just be the oil filter needs changing, but could also be something worse like a blockage or a leak!
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
