Looking for help with 2011 Yaris/Vitz radio not working saying 'insert correct sd card' ? Thanks
Rcahill
Hello,
I just purchased a 2011 Toyota yaris/Vitz. The radio/screen in it is reading 'please insert correct sd card' there is no sd card in it. I tried putting one in but nothing worked. I don't know which files or a particular sd I need maybe? The writing on the buttons is Japanese so I don't know what they are for. Any help would be appreciated.
Thanks.
Moved to the Yaris club.
Is it a Jap import ? If so, what Vitz is it ? gen 2 or gen 3 ?
The SD card is for the sat nav if it's a JDM car the radio will not work correctly and the sat nav will be Japanese only
edit. It's more than likely a 86100-52190 (26054 on the bottom left of the display surround)
To find out what the buttons do use the Google Translate app on your phone
Thanks for replying. Yes its a Jap import. It's 2011. I'm not sure about gen 2 or 3 sorry.
The numbers on the bottom left of the unit are: 76047
The numbers/letters on the bottom right are: NSCN W60
The actual screen of the unit has numbers on the bottom right also along with Japanese writing: 606226
The car did not come with any SD card. I tried googling files and uploading to my own sd but this did not work.
I'm just wondering if there is anything I can do that would get the unit working? I would be happy even if I could plug my phone in with an aux to play music if there is no actual radio? I'm a bit clueless sorry!
Thanks!
Can you PM me the vin/frame number, it's unusual to get a yaris Jap import unless its an RS or RS sport G
Found the radio  white surround with silver buttons, sd card slots in at the bottom of the screen
Edit. Is your Car actually a Toyota Ractis ?
Edit2. it needs the map card to boot it may also be password protected, But its still going to be in Japanese
The Jap manual
https://www.dropbox.com/s/j36vcy6uqt8wl2c/nscn-w60.pdf?dl=0
