Space saver wheel and jack
ICF
Does the Yaris MK4 Excel with Panoramic roof come with a space saver wheel and jack or just a tyre repair kit?
Tyre repair kit and jack, as the spare wheel puts the car into a higher tax category due to the additional weight.
The jack should be on the boot on the driver's side behind a door
You should be able to get them to add a space saver kit as part of the deal tho' if you're buying it new, although unless you are a very good haggler you will need to pay for at least some of it!
Why would you need a jack with the tyre repair kit? Did you mean compressor?
Can you buy a spare wheel from Toyota I could not see it as an option?
It's not a standard option when buying the car, but the parts department can order one for you and it can also be used as a haggling point; It will likely be extortionately expensive, but worth checking anyway.
I got a kit from eBay for my dad's verso that was something like £80 and included a jack and lug wrench. IIRC there is also a company that specialises in supplying space saver kits (Totally forgotten the name and site; Will post if I remember)
In UK, if I understand correctly, the space saver wheel is offered as satndard on all New Yaris except the ones with panoramic roof.  In Italy is offed as an option on all versions ( Lounge included ).
I wonder if there's some oher less recent car that uses the same size of space saver wheel that may be bought ad a more cheaper price from a yunkard.
Quote
Yes that what I thought but I don't know the spec of the MK4 Yaris wheels and if it comes with a jack
If the car has the can of gunk, it doesn't get a jack
Wheel size
5x100 et50 - space saver is listed as 16x4T with a T125/70D16 tyre
iirc. It's the same as the mk2 Auris/CT200/Prius
Is this space saver wheels compatible with the Excels 17" wheels?
Wheel size
16 and 17" list the same spare, the 17" uses a lower profile tyre to match the diameter of the 16" alloy set up
space savers are rated for 50 miles under 50 mph
I have purchased a 17" space saver wheel for a CT200 and was just wondering does the MK4 Excel Yaris with Panoramic roof come with the lock down screw for the spare wheel or will I have to purchase that as well.
iirc some boot trim is different as well 17" spare may be too big, but it all depends on the tire size
the hold down is 51931-0d280
https://www.ebay.co.uk/itm/324472743389?hash=item4b8c1525dd:g:BVAAAOSwZpdgGSNl
The dealer, maybe cheaper
spare tire box insert
64777-K0020     £83 for a bit of foam pmsl
https://www.toyota-tech.eu/aimuploads/c77dee18-f345-4424-a0a9-5e03c9f634c8/Yaris-Cross_Spare_Tyre_XXXX_AIM_006_143_0.pdf
  • 7 months later...
What parts would I need to secure the jack on the right side of the boot is the list below correct.
58791-K0050 jack Carrier
64766-K0070 jack Cover Lower Bezel
58778-K0020 Jack Stand Support
58796-K0030 Jack Clamp Hook
