Oil control Valve ( removal and replacement)
Matt99
Can anyone tell me how easy or difficult  it is to remove oil control valve? Is there any risk of flooding the engine with oil on removal? Not done this before, so I'm a bit nervous of getting it wrong. Thanks for your help.
Matt
Moved to the Yaris club. Which engine - 1.0, 1.3 or 1.5?
 Do you mean the vvti solenoid, 1 bolt and 1 plug, you may get a dribble of oil, it only gets oil under oil pressure eg. with the engine running
once you remove it any oil will drain back anyway
