PIP gen2 Intruder Detection system
johalareewi
Does anyone know how to turn off the intruder detection system when the plugin prius gen2 is turned off?
In the hot weather i leave the windows open but cant turn the detection off so the alarm goes off every now and then if the car is locked.
In my gen1 plugin there was a switch on the overhead light cluster but on the gen2 plugin it only seems to be available briefly on the MFD when the car is turned off.  However, turning off with the window open causes a window open message to appear on the MFD and the prompt is not available.
Doesn’t the open window message only appear when you open the door? I’ve deactivated it before with the windows open
You could be right.  I will check it out.
Silly me. Yes i had a door open at the same time.
