RAV4 T180 fault code p0093
Rem2004
Hi All
I have just bought a RAV4 T180 on a 2007 plate
When driving normally all seems fine, but if put foot down a bit and hit 4000rpm goes into limp mode with warnings check vsc system, check 4x4 system and engine management light on
Turn off for couple of minutes and all resets and is fine until hit 4000rpm again ??? Also mpg seems low even driving sensibly only returning 26/27mpg if onboard computer display is correct
Had it plugged in and diagnostics shows error code p9003 major fuel leak ??
Any ideas where to start would be appreciated
Cheers
Hi Rem 2004
Fuel is power, so I would check that, not much good at electronic cars, used to the conventional where one can get to it pronto,
As you have an electronic car it needs a computer check up by your car agent.
Moved to the Rav4 club.
  • 1 year later...
Sounds like injector problems, similar to the issues my daughter is having with her RAV4.
