Egr
rpearson1967@aol.com
Had check parking break system come up on 2014 avensis d4d. Check code and it said egr fault. Changed egr after 50 miles error came back the same. It’s intermitant error stays on for a while then goes off again does this   A couple of times a day. Car still runs fine no lack of power. Can anyone help. Thanks rob
Was the valve replaced with a new one? Also check multi plug connector if ok check rear pad wear.
What is the fault code ?
