fuse box location
freddie kearney
2011 2litre 4d4 have removed glove box can see unit containing wiring plugs,and 2 relays , but no fuse box where could they be hiding
Moved to the Auris club.
It's on the underside, in the foot well. Get under, and you should be able to see it. There is a thin cover over it or something like that.
Yes, get under there and then look, you'll get a bit of neck ache after
