I am looking for 2 reconditioned fuel injectors for a Toyota carina e 1.6 1995
Anyone able to help
thanks
  • 1 year later...
Have you tried cleaning them ?  All you need is FI cleaner, a jam jar, two small
clip on cables and a 9v Battery. also some tubing to push on the top of the injector so as to hold the cleaner.  Remove the injectors and connect the wires
to the Battery, connect one to one contact on the injector and with the tube full
of cleaner keep touching the other contact with other wire. Should click and then squirt cleaner back into the jar. Keep touching very intermittently until you feel
you get a good spray pattern !  Lot cheaper than new ones.
