2015 Verso 1.6 Dlesel
Hi Everyone
Over the last few months i have noticed that when the vehicle is cold & when gently accelerating in 2nd gear the car ever so slightly holds back between 1500 - 2000 rpm & is quite noticeable, this does seem to improve as the engine warms up.
Has anyone else had this problem with this model??  -  car is on a service plan with Toyota so is always serviced as per the schedule & i do have an extended warranty until March next year so would like to get any problems sorted before this runs out.
Many thanks
Ade
Get it booked in if there is a fault your warranty should cover it, also don't worry about the extended warranty as Toyota have introduced Toyota relax which will give you 12 months /12500 miles warranty extension when you use Toyota to service it, repeating up until 10 years/100000miles.
Have you had the recent EGR cooler recall completed?
