Touch and go sat nav not working 2012 Yaris
Camryman
Hi, my wifes 2012 Yaris has the Touch and go sound system fitted, and the Sat Nav side appears to have failed. It works for a short while then locks up with a blank screen and this then effects the normal radio,CD and line in. The other stuff works but with difficulty. I have removed the entire radio SatNav unit from the dash, and opened the SatNav box and checked all of the pc board and multi plug connections under a magnifying glass but can find no problems.
My main question is could I leave the Sat Nav unit disconnected and run the rest of the radio head unit without it?
I have seen the Sat Nav units for sale on eBay, but these days a mobile phone is far better than the original ever was, but I believe the bluetooth also is connected via the Sat Nav unit. Is that correct?
Thanks in advance
The touch (DA) has bluetooth, as does the nav module - if the nav module is plugged in it disables the bluetooth in the touch (DA)
either could be at fault, It's either heat soak or just the processor/memory starting to fail
you can go into the hidden menu and try a reset on the nav module   under General - Reset extension box
You can also run a failure Diagnostic from the other hidden menu
turn the ignition on
Press and hold the Car button and then turn the headlights on and off 3 times
failure diagnostics - System check
Thanks for the info Bob, I got into the hidden menus and found several faults listed. I cleared these, but still no joy plus the fault codes repeated. So I have disconnected the Nav unit, and the radio, bluetooth,cd,line in all work fine now. I won't be replacing the Nav unit as the cost is stupid. I have got a Garmin that will do job just as well.
do you have the error codes ?, the touch nav modules are cheaper (£80-120) than the touch2
No sorry, I forgot to write them down.
  • 1 year later...
Hi
what wires are for the radio and sat nab I have same problem I would appreciate it for your help.
  • 5 months later...
Hello, I’ve had the exact same problem. I have pulled one of the ribbon connectors out of the nav module(the one which connects into the touch module). This has solved the problem of the touch locking up and doing weird things.
however I have lost the use of the USB under the arm rest. Does anyone know if there is a way to get the USB working again but keeping the nav unit disconnected?
the touch and go has the option for the usb but it’s greyed out.
Unplug the large square gray plug from the nav module and plug it into the main unit (DA)
