2011 2.2 D-Cat Avensis Automatic transmission fluid change_advice
zsoltny
Hi all,
I purchased a 2011 Avensis with automatic gearbox and just replaced the engine oil but planning to do the transmission fluid as well.
I've received a £150 quote from a garage but would do by myself if someone could give me an advice. Also I don't trust them, what if they charge me for the filter and they actually won't replace it...
I need to know the following:
-I know where the drain plug is but where can I fill it up?
-How can I check the level after refilling it?
-Should i cange the filter as well? I would do in on my driveway so can be windy and don't want get dust if I need to take the bottom...
-Does someone has the repair manual for this?
Current milage is 89k.
Any help would be much appreciated.
