I just bought a spare wheel kit from the local Toyota dealer £194.48.
What I want to know is the rubber block "PROTECTOR, SPARE WHEEL" 64778-0H020, where do I stick it?, a photo would be most appreciated.
Cheers
If you look carefully there are two dimples evenly spaced in the floor pan at about 12, 5 & 7 o'clock the pads fit between these
Many thanks
Damn, they only gave me one, so I need three?
Can anyone point out where these rubber blocks should be placed please, in an idiot proof format please? 😁
The one inn the photo is not attached, I just left it in there when I took the photo as I had been moving about under the space saver to see if I could see where it goes.
The EPC shows them at 12, 4 and 7 o'clock
edit. They can be seen in this vid
Cheers Bob, very much appreciated
