Steering wheel switches
Starensis
Anyone know which buttons on steering wheel are used to answer phone?
try the Nav manual ? P62
https://d24bc9lyrt5en5.cloudfront.net/Customer-Portal-Admin/emanuals/TOYOTA/OM52G43E.pdf
Volume does the incoming  call volume
Enter button on the right (round centre one) is answer/hang up
Info is displayed on the gauge cluster for other options
Thanks. Not obvious at all.
I went through owners manuals and it only showed Type A controls.
I’ll give it a go - once the microphone issue is sorted. 😩
I do like that on the Mk4 there's a dedicated button with the Phone symbol on to answer/hangup - Takes the guesswork out of it! :laugh: I just hope the buttons last - They don't feel very robust!
My 2016 Mk 3 ICON hybrid has 2 phone buttons on the wheel, one to answer and one to hang up.
So does my 2014. Looks like they've overcomplicated things to try and "fix" something that didn't need "fixing".:rolleyes::ph34r:
Maybe that explains the Tech trim?:laugh:
3 gen second facelift - some have the MID display in the centre of the gauges - and the later controls, so you can use the menu system
iirc you only got the MID on 14-18 cars with the Toyota safety sense option (it was even an option on the Excel)
It does notify on centre display.  You can answer by pressing centre button on right switch cluster.
