Manual
barry66
I'v got a 1.8 GS Avensis.
I would like to get a (Haynes type) manual, but can't find one in print yet, any idea's?
I want to fit some rear brake shoes, how does the the brake (abs) system de-pressurise ?
Also, I need to replace a bulb in the dash; bit concerned about air bag in steering wheel. How to disengage? I don't wan't it going off!
Any particular problem with doing the cam belt? I've done a twin cam Corrola before and that wasn't a problem. How does this compare?
Thanks for any help.
:unsure: ARE YOU SURE THAT YOU HAVE A CAM BELT AND NOT A CHAIN DRIVE JOBBY?
Check car manual ............... I think that it says that our 1.8 Avensis does not need a cam-belt change!
Cant help you with the rest sorry!
Brian
The VVT-i engines ones are chain, the earlier non VVT-i ones are belt driven.
The best you can get Haynes manual wise is one for the CarinaE which used the same engines, yours I believe is the 7A-FE.
